Header bolts - help..
Old May 12, 2004 | 02:47 PM
FLU
Guest
Posts: n/a
have a 94 z28 and hooker shorty headers and can't get to all the header bolts- what the heck can i use to get to them?? 7/16 wrench only got the ones on driverside can't get any of the others...
Old May 12, 2004 | 04:57 PM
BUBBA's Avatar
This is where you put on your thinking cap.
I.e., take a look at the situation and determine a solution.
It might be modifying a box wrench or rachet head, etc.
It might be removing something to get at the bolt.
It might mean going from underneath the engine.
Once removed, it might mean replacing the bolt (s) with 12 pt heads so that the next time will be easier.
Other members might be able to tell you the exact solution, but sometimes the situation calls for special attention and the only one that can see the problem is the one with their head in the engine bay.JMHO
Old May 12, 2004 | 05:03 PM
ChevyIron's Avatar
I grinded down several sizes of open end and closed end wrenchs.It will be helpful too with a swivel and extensions for the ratachet.Good luck with the bolts
Old May 12, 2004 | 05:15 PM
FLU
Guest
Posts: n/a
ok i will have to try some more things. thanks guys
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
maybe2fast
Mar 16, 2015 09:45 AM
SavageZ28
17
Jul 14, 2002 11:04 PM
