header bolts come loose
Old Jul 20, 2003 | 09:52 PM
  #16
thewinner's Avatar
yes, just a little screwdriver
Old Jul 20, 2003 | 10:28 PM
  #17
Ryan 97 Ram Air T/A's Avatar
I was able to torque down most of them when I had my engine out. The others are guesses based on how tight they feel compared to the torqued ones.
I use both 12 pt and socket head bolts depending on their location. I have about half a dozen box end and allen wrenches bent and cut for tightening the bolts from all the different directions you have to reach in there. It has become an artform at this point.
Never heard of aluminum bolts either if that post was directed at me. I was talking about the aluminum heads vs the steel bolts.
Old Jul 20, 2003 | 10:32 PM
  #18
carlos64030's Avatar
You tighten the Breslin fasteners with a 3/8-inch 12-point closed-end wrench then insert an 1/8-inch hex key into the top of the fastener, turn the hex key to expand the bottom threaded end of the fastener. To remove the fastener, just reverse the process!
Old Jul 20, 2003 | 10:53 PM
  #19
Those things look like a good idea. I may try them out. Just how expensive are they?
Also, how much was is to get your wheels widened? Your car sounds exactly like how mine will be in a few years.
Old Jul 20, 2003 | 11:16 PM
  #20
I paid $65. for a set. Expensive, but worth every penny! I don't have to worry about them backing out from the constant heat cycle, and the wheels cost me $240. a piece to have done.
Old Jul 21, 2003 | 06:49 AM
  #21
dynomight's Avatar
They only come off when you want them to. They are the same as regular header bolts. After they are tightened down, there are special washers you slip over the head of the bolts. Then a c clip holds it all together. The special washer is hex-shaped on the inside. It will rest against the header pipe, preventing the bolt from backing out. 56 bucks from summit. Next to satellite television and air conditioning, its the best invention of the 20th century...
Victor Lamb
Aug 26, 2017 02:52 PM
RUENUF
Mar 13, 2016 03:39 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
maybe2fast
Mar 16, 2015 09:45 AM
SavageZ28
17
Jul 14, 2002 11:04 PM
