Header bolts
Old May 24, 2006 | 12:09 PM
josievers's Avatar
Header bolts
This is my first post on this forum. I just got done installing some Jet Hot long tubes and was wondering what you guys suggest for header bolts. My kit didn't come with any. I currently have the headers sitting in place with my Edelbrock header bolts, but they seem to be rubbing on the primaries. In addition, they are rather long and a complete nightmare to work with on the Jet Hots since the primaries are so much larger than the Edelbrocks. Thanks a bunch guys!
Old May 24, 2006 | 01:13 PM
way1and3r's Avatar
Re: Header bolts
I used the ARP header bolts on my Pacesetters. Worked really well, they have a smaller 5/16 head that has much better access than the "stock" bolts that came with the headers.
Old May 24, 2006 | 01:21 PM
94_PatriotRed_Z's Avatar
Re: Header bolts
Yea I used ARP 1 inch header bolts on my car
Old May 24, 2006 | 01:22 PM
Bow94z's Avatar
Re: Header bolts
who has the ARP's? I need some for my jet hot's aswell
Old May 24, 2006 | 01:25 PM
jbsupra89t's Avatar
Re: Header bolts
Had ARPs on the Jet Hots on my old car... worked awesome, and wrench/socket access is sick.
-J
Old May 24, 2006 | 02:30 PM
way1and3r's Avatar
Re: Header bolts
Jegs has them: Part #:070-400-1210, Kinda pricey at $30.00 but they do a good job. I bought mine at a local high performance store, if there is one close to you they should carry them as well.
Old May 24, 2006 | 02:36 PM
Bow94z's Avatar
Re: Header bolts
Thanks man
Old May 24, 2006 | 02:37 PM
josievers's Avatar
Re: Header bolts
Yeah, thanks a ton! I was going crazy trying to get those others in there. I finally had to walk away and wait for something better, because these weren't happening!
Old May 24, 2006 | 03:02 PM
way1and3r's Avatar
Re: Header bolts
No prob! I about threw a wrench across the garage trying to put the bolts in that came with the headers. These were MUCH easier, >30min install for all 6 vs. 1.5 hours or so with the stock bolts.
Old May 24, 2006 | 04:31 PM
josievers's Avatar
Re: Header bolts
Did it take about 30 minutes per side?
Old May 24, 2006 | 08:09 PM
way1and3r's Avatar
Re: Header bolts
Yeah, about 30 mins or so to get everything torqued and ready to go. I was doing a gasket swap, so the headers were already in place, just had to swap gasket and bolts. It took much longer with the stock bolts because I had to use an open ended wrench instead of a socket.
Old May 31, 2006 | 08:23 AM
josievers's Avatar
Re: Header bolts
You guys were right! Man the ARP bolts made the install easy. I had all of the bolts in and torqued down within 45 minutes! Great advice people...
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
maybe2fast
Mar 16, 2015 09:45 AM
SavageZ28
17
Jul 14, 2002 11:04 PM
