Which Header Bolts?
Old Apr 28, 2004 | 03:05 PM
drewstealth's Avatar
Which Header Bolts?
I had my Hooker LT's installed about 2 weeks ago. I noticed that above the #1 primary and #2 primary the gasket(percy's dead soft aluminum) is starting to turn brown. So i know it is leaking from there. I put all but 2 of the locking clips on the drivers side but i didn't get any on the passenger side. Now i'm having a really hard time getting the damn clips off. I have to take them off because i gotta change gaskets. So i'm wondering if the stage 8 bolts would be good to use without the locking clips or if i should go with some ARP bolts? Or has anybody tried using the Breslin bolts and how easy are those to install and uninstall the locking clips?
Old Apr 28, 2004 | 03:08 PM
Mike383LT1's Avatar
header bolts
arp#4001101
Old Apr 28, 2004 | 03:12 PM
BUBBA's Avatar
I don't know, but I used the felpro gaskets with ARP 1" SS 12pt bolts for my SLPs.
Haven't evidenced any problems yet (hope).
Problem with the Stage 8s is screwing with the locks when you need to remove bolts or retorque them. JMHO
Old Apr 28, 2004 | 04:01 PM
Do you have a summit part # for those bolts? That # you gave me doesn't seem to work. For the Felpro Gaskets do you have to use gasket sealer stuff on those? Also has anybody used the Breslin bolts and how do you like them? Thanks.
Old Apr 28, 2004 | 04:34 PM
Mike383LT1's Avatar
pt#
there pt# is arp4001101
Old Apr 28, 2004 | 04:49 PM
Thx for the part #. I gonna go ahead and order the ARP 1inch 12 point bolts from them.
Old Apr 28, 2004 | 04:57 PM
Nestromo's Avatar
I just ordered the Stage 8 locking type. Should work OK.
Old Apr 28, 2004 | 05:35 PM
I have the stage 8 on there already. But it is a pita to try and tighten them down. I gotta use a 7/16 wrench and i can't even turn the damn thing on the back 2 bolts. Also the clips don't really work with the big primaries on the hooker lt's
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
maybe2fast
Mar 16, 2015 09:45 AM
SavageZ28
17
Jul 14, 2002 11:04 PM
