tested fuel pressure today and....
Old Apr 28, 2004 | 05:28 PM
LT1 PWRD's Avatar
hooked it up to the test valve, turned the key, didn't hear the fuel pump prime so I bypassed everything and taped onto the connector under the hood to test the pump and still 0 pressure.
So am I correct by thinking that the only scenarios left are wiring problems to the pump or faulty pump?
I'll order a new pump tomorrow anyways. The car's getting old!
Old Apr 28, 2004 | 05:31 PM
HBHRacing's Avatar
if you jumped hot to the prime connector and still nothing then yes. you either have a faulty pump or wireing to it. you try beating on the bottom of the tank?
Old Apr 28, 2004 | 05:38 PM
LT1 PWRD's Avatar
That's exactly what I did,
Thanks for that link you gave me the other day.
I've heard of hitting the tank, it sometimes works but I haven't tried that yet.
Last thing left is to cutout an access panel in the trunk and test for voltage at the pump.
Is there wiring that's right before the tank tha's accessible to check for voltage without cutting that panel? Prefferably as close as possible to the tank?
Old Apr 28, 2004 | 05:55 PM
HBHRacing's Avatar
I belive if you look under the car you will see where the connetor is and can test it there. it's going to be either a grey or red wire depending on your year. jump power to the prime connector and test for volage on that wire under the car. you should also check the ground but a bad pump is more like what the problem will be
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Gtpguy
Jan 26, 2015 04:50 PM
Jul 4, 2005 05:00 PM
