Header bolt hole stripped out
Old Jun 12, 2006 | 05:42 PM
Sgt. Spuds's Avatar
I was gonna do header gaskets today, but noticed I had a loose bolt on my passanger side, and yep, you guessed it, I can't get it to tighten. Its stripped better than a 1sc... what next?
Old Jun 12, 2006 | 06:17 PM
user 647483's Avatar
Re: Header bolt hole stripped out
Sounds like an excuse to invest in ported heads
Alternatively, you can take it off and either have a shop fix it or replace it with a used head from the classfieds section or the scrapyard.
Old Jun 12, 2006 | 06:21 PM
Sgt. Spuds's Avatar
yea, I'd rather not dump any money into performance mods at this point, tired old lt1 ftl. I just want this exhaust leak GONE.
Thats the one * by 8 * think I could get it to seal with a new gasket and the rest of the bolts tight?
Old Jun 12, 2006 | 06:43 PM
PoorMan's Avatar
The head gasket will cost more than the machine work. It happened to me. The exact same bolt. I ended up sending them to Llyod for a stage 2 before I reinstalled them. Good luck.
Old Jun 12, 2006 | 07:19 PM
lt1srule's Avatar
if u have 3/4 inch bolt then use the 1 inch bolts worked for me better too ....
Old Jun 12, 2006 | 09:27 PM
Sgt. Spuds's Avatar
^^ thats what Im gonna do. I have the bolt, I have the header COMPLETELY un hooked from the car and still cant seem to get the ****er back on. I'm having the car towed tomorrow, I just ****ed with it all night, this pos isn't worth my time. I literally, hate my car right now. I can't get the header back on, I have the EGR unhooked, the header unbolted, the o2 unhooked, the old gasket out, the header is unbolted from the Y pipe, and I can't get it back together.
Old Jun 12, 2006 | 10:25 PM
matt65's Avatar
Keep us posted.
Old Jun 13, 2006 | 10:05 AM
john oliver's Avatar
i had a simular problem on the driver's side. tried tapping it with (I believe a 3/8 -16) and then a bottom tap to clean up the threads. that didnt work so i used an heli coil insert. be careful. go only a 1/2 inch deep, then tap, then the insert, then use a 3/4 inch header bolt.
good luck john
Old Jun 13, 2006 | 03:36 PM
Sgt. Spuds's Avatar
I got a guy coming over to help me out on this thing tomorrow at five thirty central. Do you guys think the header has any chance of sealing without that bolt? lol
I guess I better get ready to walk to work, gotta be there in a hour and a half
Old Jun 13, 2006 | 03:37 PM
Sgt. Spuds's Avatar
ALSO, is there a way to change the 02 with the header on? If not I will buy a o2 and replace it while the headers off.
Old Jun 13, 2006 | 03:41 PM
It won't completely seal, but with a set of solid gaskets (copper or aluminum, not paper)
it'll run pretty good; it will just tick and make your engine bay hot. I wouldn't make that a
perm solution, but it'll get you by for a while.
Old Jun 13, 2006 | 04:24 PM
Sgt. Spuds's Avatar
jb weld around header flange ftw!
lol I kid I kid, I will hopefully get this patched up good enough to run till im done with apperance and suspension mods, then I might throw a nice set of heads, and a 108lsa cam
Victor Lamb
Aug 26, 2017 02:52 PM
RUENUF
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 09:45 AM
Joes96z
Dec 13, 2014 07:48 PM
SavageZ28
17
Jul 14, 2002 11:04 PM
