headbolt torque
Old Mar 8, 2008 | 04:45 PM
Wims97T/A's Avatar
headbolt torque
Today i have started with putting the heads on the engine.
I did the method of 22ft lbs an 80 degrees for the long bolt,but found out with using the Snap-on tech angle that the actual torque is arround 56/57 ft lbs instead of the 65 ft lbs which is the most common reading older posts.
I did the same method for the rodbolt nuts and i am happy with it,but for the headbolts i'am wondering what to do now.
Old Mar 8, 2008 | 07:50 PM
Just use the torque-angle method and don't look back. Normal torquing includes friction that affects the torque reading. That is why the torque-angle method exists (to eliminate torque errors caused by friction).
Jake Bialke
Sep 24, 2015 11:31 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Bxlt1
Sep 17, 2015 08:31 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
realistyc
Jul 28, 2015 07:32 PM
