Head Torquing
Old Sep 29, 2008 | 08:38 PM
93Z28Sam's Avatar
Head Torquing
I just don’t know where to get any information concerning this subject. I know the proper GM head torque sequence for the LT1. I just don’t know which method to use. Do I just torque the heads in three step till I reach the recommended ft pounds and forget it or do I used an angle gauge? Any information in this matter would be greatly appreciated.
Old Sep 29, 2008 | 11:45 PM
Either will work. Your choice. I like the T/A method.
Old Sep 30, 2008 | 02:57 AM
SS RRR's Avatar
I've always used the 3 step method for a total of 65ft. lbs.
Old Jun 11, 2013 | 04:00 AM
will.b.brown's Avatar
Re: Head Torquing
if your name truly denotes that you own a 93 and you know for a fact that your bolts are factory installed originals then you can reuse them...but YOU dont have a choice which torquing method to use with THOSE. you will use the three step method to 65-70 ft lbs. if you use the toque angle method they WILL NOT be tight enough. If youre not sure then go to autozone or wherever for new head bolts and youll have to use the torque angle method. your third option is order a set from ARP. you can install and remove arp bolts indefinitely using the 3 step method i first mentioned.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
StansZ28
Feb 19, 2015 07:39 AM
