Head swap ?'s
Old Dec 20, 2004 | 03:24 PM
whatsup's Avatar
Head swap ?'s
Can the heads be pulled and replaced without getting into the A/C system? I know everything has to be unbolted from the head but can it be done without opening lines and loosing refrigerant?
Old Dec 20, 2004 | 03:26 PM
disco192's Avatar
Re: Head swap ?'s
Yea, you dont need to pull anything in the AC. You dont even need to pull the radiator.
Old Dec 20, 2004 | 03:43 PM
FastZ8's Avatar
Re: Head swap ?'s
it makes it 10 times easier to do without the rad and a system i would remove it
Old Dec 20, 2004 | 03:45 PM
disco192's Avatar
Re: Head swap ?'s
heads dont need radiator pulled, cam is another story. Dont mess w/ the radiator.
Old Dec 20, 2004 | 05:10 PM
FastZ8's Avatar
Re: Head swap ?'s
oh sorry i misread this i thought there was a cam in there somewhere too. Oh no you can just leave all that stuff on there .
Old Dec 20, 2004 | 08:07 PM
OBE1 95Z28's Avatar
Re: Head swap ?'s
Don't forget to remove the coolant line (steam pipe) that connects the back of the 2 heads.
Old Dec 20, 2004 | 08:56 PM
FastZ8's Avatar
Re: Head swap ?'s
that coolant pipe is a pain too get off (at least it was for me). Use the exact size on it because it will strip easily. It will take alot of grunt to get it off
Old Dec 20, 2004 | 09:03 PM
Jeff95TA's Avatar
Re: Head swap ?'s
Find a friend with small arms too!
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Brandon Wittmer
Dec 7, 2014 12:15 PM
cryptopsy
Aug 19, 2002 12:19 PM
