Head swap, drain coolant?
Old Nov 29, 2003 | 07:01 PM
ibanez6rg's Avatar
I already know I need to drain the radiator, but do I need to drain the block? All the way or just a little? Expect a lot of questions here soon
Old Nov 29, 2003 | 07:59 PM
PoorMan's Avatar
Yes. I removed both the driverside drain and the pass side knock sensor but the driverside should be enough.
Jeff D.
Old Nov 29, 2003 | 11:10 PM
ibanez6rg's Avatar
Is it necessary to drain all of it? I would think it would be ok below the pistons... Ahh, just screw it... I'll drain it all
Old Nov 29, 2003 | 11:21 PM
PoorMan's Avatar
Alot more comes out it you pull both instead of just one. At least it did in my case. You would think since its all connected it wouldn't matter that much but I had alot more drain after pulling the knock sensor. Sometimes the knock sensor is really in there good and I dont think its worth the effort because it is easy damaged if its stuck in the block. I had to replace mine because the socket part seperated from the threaded part while I was cranking on it. It's two pieces and $40 btw
Jeff D.
Old Nov 30, 2003 | 03:14 AM
trax's Avatar
I recommend opening the block plug and draining the block, then the radiator (order isn't super-important, but have buckets under both at the same time).
If you want, pop off your thermostat (watch out for coolant) and hold an air hose up to the opening and blow some air into the opening. This will get out that last little bit that always seems to soak into your pants and boxers at an inopportune time
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
Sandersen511
Jan 13, 2015 03:49 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
pologreen97z
Dec 2, 2014 10:42 AM
