Head selection help
Old May 15, 2004 | 12:01 PM
1984camaroz28's Avatar
Head selection help
What whould flow beter and produce more power with the CC306 cam on a 383. I have not selected a piston yet. so compression is not a concern in this
TrickFlow or LT4 heads
Old May 15, 2004 | 12:55 PM
kmook's Avatar
Advanced Tech Moderator
This should be discussed in LT1 Tech, transfering.
Thank you.
Old May 15, 2004 | 01:06 PM
SStrokerAce's Avatar
Re: Head selection help
Compression is a concern really. 54cc chambers in the LT4 and 64cc chambers in the TFS head. The two heads flow very close to one another stock, the LT4 head I've seen go 290cfm with the stock valve while the Trick Flow will do even better with porting and a bigger valve. Niether one of these heads is going to set any records in stock trim, and a cam other than the 306 is probably going to be better in the end.
Bret
Old May 15, 2004 | 03:17 PM
what cam do u think whould be good
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jan 23, 2015 01:13 PM
Dec 17, 2014 11:00 AM
