Head porting
Old Feb 22, 2013 | 12:42 PM
mikemassi's Avatar
Head porting
I have a 94z a4 with stock bottom end and cc503 cam. I'm pulling my heads to have them ported and milled. The machine company says he can mill the heads to what ever chamber size I want. I would like to raise the compression of the car. What would be a safe size to get them milled to? 50cc? And does anyone know what 50-52cc would raise the compression to with stock pistons? And what would the down side of raising the compression be?
Old Feb 22, 2013 | 02:03 PM
RamAir95TA's Avatar
Re: Head porting
Milling is not the correct way to increase your compression. Use the thinnest head gasket you can use without screwing up your quench. The HP gained will be negligible.
You should only go as much as it takes to true up the mating surface. Generally anything more than .020" will also require machining of the intake manifold. I usually advise .005" at a time which will allow for future "skimming" if need be.
Who is porting the heads?
Old Feb 22, 2013 | 03:17 PM
mikemassi's Avatar
Re: Head porting
AI is porting the heads. So I guess since you say combustion chamber size makes no difference in power, what size should I get them milled to?
Old Feb 22, 2013 | 03:49 PM
Re: Head porting
You aren't milling to a specific combustion chamber volume. You are milling the minimum thickness required to achieve a truly flat surface.
Old Feb 24, 2013 | 07:37 AM
redline9570's Avatar
Re: Head porting
I am sure that tweedle-dee and tweedle-dumb know what your’e talking about but to make themselves feel self important they will dig into your lack of technical terminology. I gathered you want to raise your CC and you were asking how to go about it. If your machine shop doesn’t know that maybe you should go elsewhere’s.
Old Feb 24, 2013 | 02:54 PM
Re: Head porting
Originally Posted by redline9570
I am sure that tweedle-dee and tweedle-dumb know what your’e talking about but to make themselves feel self important they will dig into your lack of technical terminology. I gathered you want to raise your CCand you were asking how to go about it. If your machine shop doesn’t know that maybe you should go elsewhere’s.
Am I tweedle-dee or tweedle-dumb?
Actually, he was asking about milling the heads to REDUCE the combustion chamber cc's.
The next time you lay down another insult, you will be gone from this site.
oldschool
Feb 9, 2016 09:21 PM
Dmonty
Jun 2, 2015 11:19 PM
cmyname1
Feb 19, 2015 08:38 PM
Roadie
Feb 16, 2015 10:34 AM
Killer94z
Jan 13, 2015 12:06 PM
