head porting
Old Oct 29, 2003 | 09:16 PM
toolmaker's Avatar
head porting
Can anyone tell me how much can be taken out of the exhaust ports of an aluminum lt1 head?
Old Oct 30, 2003 | 07:58 AM
Engine specific tech questions should be posted on the appropriate tech forum. Moving to LT1 Tech......
Old Oct 30, 2003 | 08:20 AM
S.J.S.'s Avatar
I am definately no expert but I just finished my heads after 49 hours of porting and polishing. I got tips from the big boyz. here is what they told me. As far as the exhaust ports are concerned.....you don't wanna match port them like the intake runners. For the exhaust port you need the step from the headers to the heads. Also FROM what they said this is what I did. I took some material off the guides and raised the roof of the port a little. The exhaust ports on the LT1 heads flow pretty well from the factory so not much needs to be taken out. You don't wanna go to far and grind into the water jacket which is close. I just took some off the guides.....the roof....and polished them up like a mirror with some cross buffs.
good luck. Take your time.
Old Nov 1, 2003 | 07:06 PM
toolmaker's Avatar
Thanks for the info.
Old Nov 1, 2003 | 08:06 PM
dnz28's Avatar
On your intake did you trim the gaskets a little over sized that way you get more flow?
Old Nov 2, 2003 | 12:02 PM
S.J.S.'s Avatar
Just a lil for the match porting.
oldschool
Feb 9, 2016 09:21 PM
Dmonty
Jun 2, 2015 11:19 PM
cmyname1
Feb 19, 2015 08:38 PM
Roadie
Feb 16, 2015 10:34 AM
Killer94z
Jan 13, 2015 12:06 PM
