Head Milling
Old Mar 7, 2006 | 06:10 PM
hektyk's Avatar
Head Milling
I am sending my heads off to have them resurfaced. Should I havethem milled down a little bit. Like up my compression a half a point. What do you guys think. I have a friend that says it's really worth it. It will only cost 5.00 extra to have it done. :-p
Old Mar 7, 2006 | 06:12 PM
MeanGreen97Z's Avatar
Re: Head Milling
Well it all depends on what you plan on doing with the car. More compression is usually a good thing but keep in mind you have to account for all this when doing a cam. Not just a go for it mod.
Old Mar 7, 2006 | 06:53 PM
hektyk's Avatar
Re: Head Milling
Well I am, doing a cam. LT4 Hotcam, LT's, 1.6 RR's, CAI, CatBack, Custom PCM, Offroad Y pipe. My friends says it will really come alive if I up it a little.
Old Mar 7, 2006 | 07:44 PM
FastZinTennessee's Avatar
Re: Head Milling
I would have the head milled enough to get it flat again, no more. If I were after more compression I would use the thin (.029) headgasket from Mr. Gasket.
Old Mar 7, 2006 | 08:53 PM
Joe B's Avatar
Re: Head Milling
Yea, I agree... for what your doing right now with the mods you listed, I would just have them cleaned up, their probably gonna take 10thou or slightly more anyway (which will help) and then go with the MR Gaskets 26thou thickness....or the impala 29thou thickness head gaskets to get your compression up a bit.......
Old Mar 8, 2006 | 12:27 PM
hektyk's Avatar
Re: Head Milling
Do you guys happen to know the part number on that?
Old Mar 8, 2006 | 12:29 PM
TransAm396's Avatar
Re: Head Milling
the MR gasket headgaskets are .26 thick. the impala gaskets are .29
Old Mar 8, 2006 | 01:55 PM
Joe B's Avatar
Re: Head Milling
Yup , like I said ...............As far as the part numbers,The impala's are 12553160....and the MR gaskets are 5716....the MR gaskets come packaged "two" head gaskets per package....summit and several of the other retailers sometimes aren't aware of this when you place the order since their so cheap, about half the cost of most good quality head gaskets......my point is you just need one pack.....Joe
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Victor Lamb
Aug 26, 2017 02:52 PM
Roadie
Feb 16, 2015 10:34 AM
NewsBot
Dec 28, 2014 06:20 PM
