Head Milling
Head Milling
I am sending my heads off to have them resurfaced. Should I havethem milled down a little bit. Like up my compression a half a point. What do you guys think. I have a friend that says it's really worth it. It will only cost 5.00 extra to have it done. :-p
Re: Head Milling
Well it all depends on what you plan on doing with the car. More compression is usually a good thing but keep in mind you have to account for all this when doing a cam. Not just a go for it mod.
Re: Head Milling
Originally Posted by FastZinTennessee
I would have the head milled enough to get it flat again, no more. If I were after more compression I would use the thin (.029) headgasket from Mr. Gasket.
Re: Head Milling
Yup , like I said
...............As far as the part numbers,The impala's are 12553160....and the MR gaskets are 5716....the MR gaskets come packaged "two" head gaskets per package....summit and several of the other retailers sometimes aren't aware of this when you place the order since their so cheap, about half the cost of most good quality head gaskets......my point is you just need one pack.....Joe
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Victor Lamb
Aug 26, 2017 02:52 PM
NewsBot
Dec 28, 2014 06:20 PM
