Head Gaskets
Old Aug 21, 2004 | 10:47 AM
Wildwill2855's Avatar
Head Gaskets
When installing new head and intake gaskets is it nessecary to buy new head bolts, i bought some their 29.99 each and i had to buy to if i dont need them man im takin them back to autozone
Old Aug 21, 2004 | 10:54 AM
Myxtreme1's Avatar
Re: Head Gaskets
I have heard it is best to use the old BOLTS if possible. They should be checked very closely and cleaned up, but I am not too sure.
Old Aug 21, 2004 | 04:20 PM
Re: Head Gaskets
That dude was like well, their torque to yeild bolts so you need new ones, and i dont think that i will because thats a bit of money to me for some damn bolts
Old Aug 21, 2004 | 05:35 PM
Myxtreme1's Avatar
Re: Head Gaskets
Yeah they are high, maybe someone else will chime in soon and help us both out.
Old Aug 21, 2004 | 07:31 PM
cmking26's Avatar
Re: Head Gaskets
I have always been told NOT to reuse head bolts something about them being torqued and then re torqued. Intake bolts I reused mine but for heads I would spend money and buy new.
Old Aug 21, 2004 | 07:44 PM
91RSLT1's Avatar
Re: Head Gaskets
For 29.99 EACH no way would I buy those. You can get ARP bolts or even ARP heads studs for far cheaper. It is best to use new bolts, to obtain an accurate torque reading. New or old that is your call, but you mine as well put new ones in while you have it apart. If it were me In would go ARP bolts or studs. Hope that helps.
Old Aug 21, 2004 | 08:44 PM
97WS6SCharged's Avatar
Re: Head Gaskets
ARP head bolts will be fine, and they're only $55 for the entire set.
Old Aug 21, 2004 | 08:55 PM
RedHottG2's Avatar
Re: Head Gaskets
Ehh that guy is crazy and just trying to make mony. Take them back and get the ARP bolt/stud kit. There alot stronger then stock and they come with a cool sticker.
Old Aug 22, 2004 | 05:02 AM
sssalah's Avatar
Re: Head Gaskets
The newer LT1's came with torque to yield head bolts that mustn't be used again because they're stretched to the yield force. Get a set of ARP 134-3601 bolts, they are strong and you can tight/loosen as much as you like.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
