head gasket swap, same problem. please HELP
Old Jul 10, 2007 | 03:42 PM
blknblu's Avatar
Well I just bought a 97 TA with a 383 stroker with ported heads in it that had 18k miles on the engine. It sat for about a year but was started occasionally (so I was told). Well 10 min. on my first ride I laid into it and a big cloud of white smoke came out and car died. I assumed HG and bought a new set. When I took off the intake the right bank head runners on the last cyl. were basically full to the top with antifreeze. I changed the headgasket, put it back together and started it up. Almost right away the right bank had steam coming off by the headers so I shut it off to see if it was just burning old antifreeze off or new stuff. I did not see anything wrong so I now added antifreeze to the radiator (it was low from before when it broke) and then the car turned over a little and locked up, from being full of water again. This time when I pulled off the intake BOTH heads had the runners full of water on the last cyl on each side of engine. I am thinking that the right side has a cracked head (I visually inspected it but saw nothing when i previously had it out). My question is have any of you guys ever saw this before? It is my first time digging into one of these engines and I could guess all day long but would rather hear from the experts
Also, there are not any shops around here that can test the head for leaks, I am basically on my own. Sorry for the long post, just wanted to be accurate.
Old Jul 10, 2007 | 05:45 PM
rskrause's Avatar
Moderator
Cracked head or cracked block. Can you get your money back? Now we know why it was sitting.
Rich
Old Jul 10, 2007 | 08:36 PM
blknblu's Avatar
how will I know if it is the block? I bought a head from a guy on this forum this evening so I was just gonna throw it on and hope for the best. Let me know ifyou have any other suggestions.
InfernalVortex
Jan 17, 2015 09:35 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
nophix
Nov 30, 2014 10:26 PM
thenewkid
Nov 27, 2014 09:41 AM
