Head gasket to raise compression?
Old Mar 6, 2003 | 02:38 PM
NXz28's Avatar
I heard that depending on the thickness of the head gasket i use, i can raise the compression ratio of the engine...is this true?
IF so what gasket thickness should i use to raise compression 1 point from the stock 10:5:1?
Do you know where i can get a entire gasket set for the car? I need head, intake, header, water pump,and timing cover gaskets...
Old Mar 6, 2003 | 02:44 PM
norcalstreet's Avatar
I believe both the Felpro and Impalla SS gaskets are thinner. It does little to effect compression but helps in the quench. I believe gains are minimal.
Old Mar 6, 2003 | 02:47 PM
4DRSS's Avatar
The thinnest LT1 head gasket I know of is made by Mr. Gasket, they are .026". The Impy gaskets are .029" and the Fel Pros are .039".
I use the Mr Gaskets, been on the car for three years, no problems.
Gripenfelter's Avatar
The Impala head gasket is thinner.
I think the Felpro raises your compression 4 points?
Dunno how much more the Impala one raises it.
Old Mar 6, 2003 | 02:56 PM
nateh's Avatar
You should only pick head gasket thickness to optimize quench. But since quench is so bad stock, putting a thinner gasket both helps quench and raises compression. Going to the .029 Impala gasket will raise compression to ~11.08:1. That is assuming the pistons are .025 in the hole at TDC. If you find a .026 gasket, it will rise to 11.16:1.
Old Mar 6, 2003 | 03:11 PM
GN231's Avatar
Nxz28, you should look at either Summit Racing or P.A.W. for full engine gasket kits. they sell everything from full engine gasket sets to full engine rebuild kits (including crank).
Old Mar 6, 2003 | 03:38 PM
Max 93's Avatar
Do you have the part # for the Mr. gasket?
Old Mar 6, 2003 | 07:11 PM
Mindgame's Avatar
Going from a .049 thick gasket to one .029 thick is gonna get you about .8 points of compression increase. Assuming the gaskets are both the same bore size.
-Mindgame
Old Mar 7, 2003 | 01:00 AM
allmotorta's Avatar
Are there any down sides to going with a thinner gasket like the Mr. Gasket one thats .026? Longevity, detonation, etc...Thanks!
Magenta_Hearts
Mar 25, 2015 10:24 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
thenewkid
Nov 27, 2014 09:41 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
