Head Flow % increase?
Old May 8, 2008 | 10:08 PM
95zsean's Avatar
The local shop i took my heads to said they measured a 17% increase in flow over stock. I had them install 2.00/1.55 SS valves back cut and port them.
The question is, is that a reasonable gain? I will get the flow sheets when i pick them up.
Old May 8, 2008 | 10:38 PM
PortMasters's Avatar
a 17% increase would be roughly a 30cfm gain over stock..roughly 235-240 cfm
Old May 9, 2008 | 05:51 AM
95zsean's Avatar
So my 374 did not flow 224 cfm stock? I was shooting for 260cfm, and he said that would give it to me.
Old May 9, 2008 | 08:31 AM
Depends on the bench really. My bench will usually get anywhere from 195-205cfm from stock casting lt1 heads. So that gain is with my bench as a baseline...flow benches vary wildly and they shouldn't..but they do. If your heads on his bench flow 224 stock, thats a little on the happy side, but just look for the amount gained total from baseline to modded..generally speaking a good set of stage 2 heads will result in a 60cfm gain for an LT1 head on the intake and 30-40cfm on exhaust.
Old May 11, 2008 | 10:34 AM
95zsean's Avatar
I will get the flow sheets next week. I just hope they will support the cc503 I have installed. Look in my sig for the rest of the stuff that goes with the heads & cam.
Old May 11, 2008 | 09:46 PM
seawolf06's Avatar
The cc503 can work with stock unported heads, so you should be good with a little port work. I just hope you didn't pay too much for a modest increase.
Did they compare the flow numbers with the stock valves versus the new ones, or just before and after? I'd like to see how much of a difference those made.
Old May 11, 2008 | 10:44 PM
Seawolf is right,
Even if you gained anything it will help, the 503 is a very cool street cam for LT1's with stock AND ported heads.
Old May 12, 2008 | 04:59 PM
95zsean's Avatar
It was with stock valves and after the new valves and port work. When I get the sheet I will post it in this thread.
As for what I payed, it was $600 with the new valve and springs install(I brought them to him)and the port work. This was his FIRST set of LT1 heads but he has done really good work on SBC stuff. He claims that 17% on stock SBC heads is unheard of, so he was quite happy with these. I did give him the flow numbers of the LE2's but he said he was worried to make the head too thin to get those numbers.
OH well we'll see what the dyno says in a month.
Old May 12, 2008 | 05:01 PM
95zsean's Avatar
Seawolf is right,
I hope it makes the car REALLY FUN TO DRIVE!!!
Maybe next winter I'll send them to you to finish what he started!!!
Old May 12, 2008 | 05:20 PM
The Engineer's Avatar
Remember; The faster the car goes, the more fun it will be to drive.
WD
Old May 12, 2008 | 05:32 PM
95zsean's Avatar
WD
LOL!!!! The problem with that is, next thing I'll be at the track breaking stuff, and wanting to go FASTER!! It's a DRUG and not a cheap one.
Old May 12, 2008 | 09:18 PM
Z-RATED94's Avatar
Yeap, but it sure is fun. Good luck with the outcome of the heads.
DirtyDaveW
Mar 15, 2015 07:01 PM
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
95chwagon
Jan 13, 2015 09:19 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
