head bolt sealant?
Old Mar 25, 2009 | 08:05 PM
  #16
udlose94z28's Avatar
is this the correct stuff?? i mean if its not ill do it over with the right stuff while its on the stand.. What were you referring to the high temp thread sealant??
Old Mar 25, 2009 | 08:21 PM
  #17
ACE1252's Avatar
Well, the Permatex High Temperature Thread sealant is what I use. Other people have used Permatex #2 with good results. I've read of leaks, on head bolts, with the #2 even with proper prep of the threaded surfaces. The thing is that the application sheet for the #2 does not provide a pressure resistance rating for it...and your cooling system is going to be under pressure. Permatex High Temperature Thread sealant has a pressure resistance rating of 10,000psi.
I'm not saying that #2 isn't going to work, but for myself, if the application sheet does not say head bolts, I'm not touching it. I can tell you that I've used Permatex High Temperature Thread sealant on my oil sending unit, waterpump bolts, rocker studs, and intake manifold bolts with zero problems. I also properly prepped the threads and allowed for complete curing time.
Lord willing, when I swap my heads, I will be using it on my head bolts too.
I bought the big tubes online because the auto parts stores seem to only carry the small tubes and will nickel and dime you to death on it.
There was one instance of where I bought a tube of the Permatex High Temperature Thread sealant and it was really watery and runny. Don't use it if it's like this....it should have the consistency of a good hand lotion.....just don't use as "hand lotion".
  #18
http://www.permatex.com/products/Aut..._2_Sealant.htm
This is the stuff i bought and used on the head? yay or nay? will it work, is it the right stuff?
Old Mar 25, 2009 | 08:22 PM
  #19
ACE1252's Avatar
We posted about the same time....see above your post....
Old Mar 25, 2009 | 08:26 PM
  #20
ACE1252's Avatar
Originally Posted by MachinistOne
Just spread some around half the threads or so, if you're unsure - more is better than less and it will only look excessive to the next guy taking it apart.
I personally coat all the threads and simply wipe off the excess after the bolt is torqued. It is a little wasteful, but better to do it once than have to do it again.
Old Mar 25, 2009 | 08:38 PM
  #21
well the one head is on there good with that stuff... is it worth my time to take it back off and do it with that other stuff or will it affect my bolts or gasket doing that? i plan on using the stuff ur talking about on the other head haha see which one holds up
Old Mar 25, 2009 | 08:44 PM
  #22
ACE1252's Avatar
Hehe, let us know how it goes!
Old Mar 25, 2009 | 09:02 PM
  #23
if it is not sealed properly will i notice it within a day after it runs or is it one of those things thast eventually **** up? And u said u have heard of people using that it and it works fine?
Old Mar 25, 2009 | 09:23 PM
  #24
ACE1252's Avatar
Here is one example.....
https://www.camaroz28.com/forums/sho...thread+sealant
There are other debates on the board of it too.
Old Mar 25, 2009 | 09:41 PM
  #25
great, that helped.. so some are for it and some are against it.. i cleaned my block and blew in the holes with the air compressor, i feel pretty good about it so i guess imma go with it and juse use the other stuff on the next head.. if it leaks, ill tear it down and do it over lesson learned but i cant see doing that now and having to retorque the bolts clean everything all over again when the chances arent too awful bad of it leaking thanks man ill let you know how it goes
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
