Head bolt leak
Old Jan 12, 2006 | 05:55 PM
383TransAm's Avatar
Unhappy Head bolt leak
When I built my 383 stroker motor 3 yrs ago I used ARP studs all around on the mains & heads.
I also used ARP thread sealer on all the studs for the heads.
Now I have a leak coming from the stud on the bottom row by cylinder #3
Is there some thing that I missed or should have done to prvent this?
After I put the studs in it sat for about 1-2 days before I put on the heads if that matters at all.
Old Jan 14, 2006 | 04:19 PM
383TransAm's Avatar
Re: Head bolt leak
No one has any sugjestions on how I could keep this from happening again??
Old Jan 14, 2006 | 05:12 PM
FastZinTennessee's Avatar
Re: Head bolt leak
I have heard of studs being prone to leaking for a while now. My machine shop guys said it was nothing to worry about, so I went with studs. After about 20 minutes of run time there was water seeping out between the block and head on the passenger side.
Apparently ARP will tell you to add some of that radiator stop leak to the cooling system. I have also been told that the cooling system tablets that GM sells work very well- that's what I'm going to try.
Old Jan 15, 2006 | 10:25 AM
383TransAm's Avatar
Re: Head bolt leak
Thanks, I'll have to give it a try.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
ModdedNerd
Jan 29, 2015 07:23 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
