having some problems
Old Oct 4, 2008 | 11:28 AM
83tpi_3rd-gen(sri)'s Avatar
the car is a 95 t/a,it only has bbk shorties other than that its stock.i got the car for dirt cheap and it ran like crap.i just changed the plugs and wires,took the car out and it ran awesome,i was very happy and impressed.on my drive home from the shop the car started to break up very bad,it wouldnt rev over 2k without just popping out.i thought it might be the coil breaking up so i went to change it and found bare wire on the coil connecter,i repaired that and im still having the same problem.do you think it could still be the coil itself or something else?the only code the car throws is egr when your getting on the freeway.thank for all the help in advance
Old Oct 4, 2008 | 02:41 PM
mrmint69's Avatar
Plug wire might be burnt on the headers.
Old Oct 4, 2008 | 02:55 PM
plug wires were just put on yesterday
Old Oct 4, 2008 | 03:37 PM
94arcticwhiteM6's Avatar
it doesnt take long. that was the start of my recent nightmare that led to 2 new optis and a lot of busted knuckles.
Old Oct 6, 2008 | 08:15 AM
plug wires are ran right and that is not the problem.now when the car still does the same thing(pops and bangs out under a load when warm)until the SES light comes on then it runs perfect.does that make sense to anyone?or has anyone ever had this problem before?
Old Oct 6, 2008 | 08:53 PM
mrmint69's Avatar
I believe the car goes into limp mode when certain codes are set so check the codes? If you only get the egr one than I'm stumped.
Old Oct 6, 2008 | 09:12 PM
LaredoZ28's Avatar
try the coil. i dobut its the problem but its worth a shot. sounds like its missing pretty good. my first thought was plug wires but u said they were ok so replace the coil and coil wire.
Old Oct 6, 2008 | 09:48 PM
blwnlt4's Avatar
If it goes away when the MIL turns on and runs fine afterwards, then its not the ignition coil are you sure its an ignition problem or possibly a fuel sys problem?
Old Oct 7, 2008 | 12:19 PM
i replaced the coil and still have the problem.it had a nasty miss befor i did the tune up on it but it didnt act like this so im not sure what to think of it.im starting to wonder if i got a bad opti or maybe its the maf.i have a spare maf laying around so im gonna try it and ill udate you guys.thanks for the help
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
