Having an "oh sh*t" moment...need some advice
Old Mar 14, 2023 | 12:59 PM
  #16
Hamip's Avatar
Re: Having an "oh sh*t" moment...need some advice
Thanks for the info. I think I am going to start with basic maintenance and flush and fill the cooling system (using the process on the shoebox site) and do a combustion leak test first. If there's no leak, then I will probably bypass the oil cooler first.
She's not running hot, or blowing smoke, the heater works, and the oil looks clean, so rather than throw parts at it I am trying to be methodical. The stuff in the radiator isn't like a milkshake consistency and the radiator cap is clean as is the oil filler cap.
Again, I really appreciate the advice.
Old Mar 14, 2023 | 02:29 PM
  #17
Originally Posted by Chimera96
the oil cooler lines going to radiator go to a sealed tank inside the side tank of radiator. If that inside tank leaks, than engine oil gets into coolant....and conversely coolant could enter oil system. disconnecting the engine cooling lines from radiator would stop that but not fix the leaking oil tank inside the radiator then coolant would start leaking "out" the open fittings where oil cooler lines were on radiator "if" that tank is in fact leaking. If that was the case you will need a new radiator
your choice on whether to reinstall the external cooler or not and use a bypass hose instead.
I think we may be confusing him. See my post #12, which has Shoebox's diagram of the 1995 oil cooler hookup. One pipe on the cooler receives coolant flow from the water pump. The other hard line for the oil cooler connects to the base of the radiator. There is no return line from the radiator to the cooler. It is circulating (edit) coolant, not oil (end of edit).
http://shbox.com/1/oil_cooler.jpg
What you are describing sounds more like the transmission oil cooler.
Old Mar 14, 2023 | 05:19 PM
  #18
Hamip's Avatar
IMHO an external oil cooler outside the radiator is ideal. No internal radiator tank issues on that type of setup
Originally Posted by Injuneer
I think we may be confusing him. See my post #12, which has Shoebox's diagram of the 1995 oil cooler hookup. One pipe on the cooler receives coolant flow from the water pump. The other hard line for the oil cooler connects to the base of the radiator. There is no return line from the radiator to the cooler. It is circulating (edit) coolant, not oil (end of edit)..
Going by the pictures, to me, it looks like it circulates coolant driven by the water pump to the oil cooler housing and back to the radiator, which is why you would put a bypass hose from the water pump down to the fitting on the bottom of the radiator to close that loop once the oil cooler assembly is removed. The cooling is done at the filter location with the cooling adapter acting as kind of a heat sink. Is that correct?
Old Mar 14, 2023 | 08:46 PM
  #19
I had a typo in my response which was further adding to the confusion. I corrected it in my post and in your quote of my post.
The water pump sends “cool” coolant to the oil cooler at the filter, where the coolant removes heat from the oil. “Hot” coolant returns to the radiator. Coolant is circulating, not oil.
Sorry about that.
Old Mar 15, 2023 | 05:45 AM
  #20
Hamip's Avatar
I figured it was a typo. Thanks!
Old Mar 15, 2023 | 08:32 AM
  #21
You seem to be describing the transmission oil cooler. No engine oil passes into the radiator. Probably just a slip of the mind.
Old Mar 15, 2023 | 08:52 AM
  #22
Chimera96's Avatar
OOPs, my bad guys. Thanks Rob for the note. Been 20+ years since I went external (not to radiator) oil cooler and my FSR radiator has no provision for "cooler" lines.
Old Mar 25, 2023 | 12:49 PM
  #23
Hamip's Avatar
Good news. Finally had some warmish weather to dive into the car issues.
After draining some of the coolant, it really isn't "milky" at all but there is some brownish residue on the inside of the radiator and in the reservoir but nothing that a proper flush and fill won't take care of. I did a check with a block tester with the car properly warmed up and the heater running, and after one squeeze I couldn't even suck air in with the bulb, which according to the tester means no combustion leaks.
The very minor oil leak looks to be coming from (surprise) the back of the intake manifold. I will deal with that one once spring has fully sprung in these parts.
I have a bypass hose, etc. to delete the oil cooler and I probably will do so on the first oil change (the oil looks great).
Thanks again for all of your help!
Old Mar 25, 2023 | 02:15 PM
  #24
Glad you got it sorted out !
Old May 23, 2023 | 12:35 PM
  #25
Hamip's Avatar
Originally Posted by annamarks
SPAM with harmful embedded links deleted. annamarks is a fake name/SPAMMER
I am working on a few other things before I dive into the leaks, but I appreciate the guidance.
Working on this car has been time-consuming, but that's fine. I am getting to know her as I go. It wasn't driven hard, so I don't think some of these parts, plugs, or wires have been so much as touched in 28 years outside of routine maintenance. I am taking care and being as deliberate as can instead of charging ahead as I usually do.
Old May 23, 2023 | 12:47 PM
  #26
Forget the above (deleted) post between #24 and #25. “annamarks” is a spammer. What he/she (??) posted is a copy and paste from post #4 by Chimera96.
ADMINISTRATOR
chasejoker
V6 Tech
Nov 18, 2014 10:05 PM
Gerg007
May 2, 2010 01:58 PM
jtreadwell
V6 Tech
Jul 13, 2008 03:11 AM
z28rider78
Nov 6, 2007 06:11 AM
DSM PImp
Jul 30, 2007 10:24 AM
