Having an issue with a high idle.
Old Aug 21, 2007 | 08:17 PM
MeanGreen97Z's Avatar
I've searched up and down for vacuum leaks... cant seem to find any. Car runs like a top but sits at 1000 - 1100 rpms at idle. I want to adjust the screw in the TB but I doubt that is the case. Anyone near Dallas have a scanner? I wanna check my sensor readings.
Old Aug 21, 2007 | 08:32 PM
mdacton's Avatar
did this start after the TB was installed?
check the IAC counts etc. guess you just need to get some info/scanner
Old Aug 21, 2007 | 08:35 PM
It was doing it with the original TB... it's starting to **** me off. This high idle is really driving me nuts. Think an exhaust leak could cause the 02s to have incorrect blms and in some way affect the idle? I am going to try a few things... I am starting to remember why I sold my 93 and got a bike. LOL
Old Aug 22, 2007 | 08:44 PM
Severous01's Avatar
run to autozone. they use the actron model that has a realtime pcm viewer. forget the real name for now but you get the point.
any way, tell them you want to use the scaner and look up the datastream. find your IAC counts. should be between 12 and 50.
PCLZ28
Dec 24, 2015 05:19 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
Dark Zeiro
Mar 11, 2015 07:15 AM
David Dorris
Jan 17, 2015 08:10 PM
