Having a few problems, could use some advice.
Old May 10, 2005 | 12:20 AM
Formula03's Avatar
Well, have been noticing a miss that starts about 5800 and goes to the shift at 6500. Its like it is studdering, kinda sounds like it is hitting a rev limiter but its not. I just replaced plugs (NGK TR6, .040 gap) and coil (MSD blaster) and it ran fine for about 3-4 runs now it still cuts out about every other run. I did notice that the lights are flickering, so I am thinking that the alternator is going and I will be changing that tomorrow. I datalogged it tonight and the volts were ranging from 10.3-12.7, mostly between 11 and low 12's, would this be causing the cutting out? I also had a trouble code, 36 HI res failure. I erased it and it didnt come back. I also noticed that the spark advance was going all the way to 42 degrees and this seemed abit high to me, what is everyone else running?
Old May 10, 2005 | 08:48 AM
Formula03's Avatar
Re: Having a few problems, could use some advice.
Anybody have any ideas?
jj_burchiel
Mar 21, 2015 12:51 AM
jj_burchiel
Mar 5, 2015 07:05 AM
camy 1993
Feb 3, 2015 06:26 PM
tds1213
Nov 27, 2014 12:55 PM
matt104a
Feb 10, 2005 03:27 PM
