Have gauge pod, what gauges you guys feel worthwhile?
My setup:
A-pillar pod - tranny temp, oil temp
Center A/C vent - fuel pressure, nitrous pressure, oil pressure
Steering column - ScanMaster
I would skip the A/F gauge. The coolant temp becomes superfluous if you have the ScanMaster, since you can see the exact temperature the PCM is seeing.
I also have EGT for #5 cylinder in the MoTeC engine management computer, and it seems to be of relatively limited value, unless you log it for a complete pass. It isn't something you could eyeball as you run the 1/4-mile, and that's the only time it gets hot enough to be important.
Thanks guys, really appreciate all the thoughts. Def. fuel pressure, now just have to decide. If AF is worthless, I like vacuum,oil temp,coolant temp...........need another pillar pod!!
I love this board. Thanks
99TransAmWS6
Feb 12, 2015 07:23 PM
