Have gauge pod, what gauges you guys feel worthwhile?
I was thinking fuel pressure reg. and AF ratio gauges. But, I've heard some say the AF ratio is worthless. I can have 2, which ones??
Originally posted by Prince
Boost and Nitrous Pressure guages would be pretty nice
MMMMMMMMmmmmmmm Boooooost......
Yeaaahhh.Id say fuel pressure if your gonna have NOs and if not A/F w/ tranny temp.
Later,
-JOhn
I think extra gages are useless unless you need them for your setup. Why not look at getting something like a scanmaster. If you have your heart set on gages then I would get a fuel pressure gage (180.00). That is probably all that is needed until you either decide to go nitrous, supercharger or turbo.
Fuel Pressure definitely. I've heard the A/F gauge is worthless though. Not too sure how helpful the Oil Temp would be though if your coolant temp guage in the dash works. EGT woud be helpful with nitrous.
I'm in the same boat. I want to get a full pillar pod (the integrated, not the single or dual that you have to screw into the pillar) but they only make dual and I need to try to figure something else out to stick in there.
