Have Biult Sheet, How to Read? Do I Have 1LE?
Originally posted by AdamZ1LE28
Yeah it does not say 1LE on your options list...so it most likely isn't one. A '96, like mine, would have hard top, manual windows, door locks, mirrors, and seats. The only options it could have is AC (new in 96), and rear window defogger. Check the shocks, they should be yellow Bilsteins.
If it's an SS what you need is the SLP build sheed which is on the end of the passenger door, or the SLP window sticker. This will tell you what SLP options the car has. Since it has yellow (Bilstein) shocks and it's a 96, then is should have the SLP Level II suspension, which includes custom Eibach springs that lower the car approximately 1/2" from stock, custom valved Bilstein shocks to match the springs, 32mm 1LE front sway bar, and 1LE LCAs and panhard rod. There are lots of other options that the car could have, but you'll need one of those SLP sheets to tell you for sure.
Henson071
May 4, 2015 12:23 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
