Has anyones valve seats ever broke out?
Old May 24, 2003 | 10:51 PM
Thor39's Avatar
My valve seat fell out of my head the other night and caused abunch of damage on my new rebuilt engine... is there any reason this happened ? The car did not over heat. there was no knock befor this happened . was this just a case of bad luck or what?????
Old May 24, 2003 | 11:56 PM
CompAirflow's Avatar
OMG-
Were the heads worked on at all? were they a complete assembly with the shortblock?
The valve seats REQIRE a certain amont of press. especially into a head like the LT1. If it does not have enough press, the seat will literally fall out of the head due to the different expansion rates of aluminum and steel. If it wasnt overheated (which wouldnt really matter in this case, the seat should have enough press to withstand extremely high tems without falling out) I would have a SERIOUS talk with the engine builder.
This is not your fault. I would be pissed. It is bad luck, but it is due to someone else's mistake.
Old May 25, 2003 | 09:28 AM
Thor39's Avatar
Yea but no one did any work on the heads with the seats. they were watch ported and that is it ??????????????????????????
Old May 25, 2003 | 10:19 AM
Mindgame's Avatar
Very strange.
The heads have never had major work? No valve seat replacement? No welding?
Maybe too little press fit tolerance but that's unlikely....... who knows.
-Mindgame
Old May 25, 2003 | 12:15 PM
PGR's Avatar
PGR
Our Datsun 510 had a valve seat that poped out, after 275k miles.
With aluminum heads, the valve seats are hardened steel rings that are pressed into the head. Depending on the manufacturing tolerances, age, wear, heat etc. they can work loose, although its rare.
Curios, was it the intake or exhaust seat?
Old May 25, 2003 | 12:18 PM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
When i got my cam put in one of my valve seats was cracked and almost broke. I was lucky i put the cam in when i did or i would have dropped a valve into my engine............
Chris
Oh yeah and i had NO previous head work done and only 65K on the engine!!!!!!! ****ty GM quality i guess.
Old May 25, 2003 | 03:29 PM
Thor39's Avatar
there was no major head work done and none to the valve seats.
I match ported the heads and that was it. they came off My stock engine and that only had 60k on it !!!!!!!!!!!!! So about $600 later im going to be putting it back together!
Old May 25, 2003 | 04:29 PM
That sucks dude. Well I hope you figure out the problems and fix them. Good luck man...
Chris
Cam's maro
Jan 8, 2015 05:01 AM
birdblack
Dec 30, 2014 06:59 PM
Cam's maro
Dec 29, 2014 08:44 AM
nikko
Dec 2, 2014 03:43 PM
