Couple of LT1 Questions
Old May 24, 2003 | 04:37 PM
AirForceAMMO's Avatar
I just had a 355 with ported and polished heads and LT4 hot cam kit. What injectors do you guys recommend I run on this motor? Brand, supplier, and pressure?
I am putting LS1 front brakes on the car too. I have the spindles and calipers. What brake lines should I run? LS1 or LT1?
Any constructive comments would be greatly appreciated.
Old May 24, 2003 | 04:38 PM
madwolf's Avatar
Go with some 30# Ford SVO injectors for the motor.
As for the front brakes, use the LS1 ones.
Old May 25, 2003 | 01:54 AM
Thanks madwolf, anyone else?
Old May 25, 2003 | 04:26 PM
Zulater's Avatar
30# SVO's will be plenty. Stock 24lbs are good up to 400 rear wheel though as long as in good working condition. If you have a lot of miles on them go ahead and upgrade to 30lbs. You will need a reprogram for them.
Jon
Old May 25, 2003 | 04:30 PM
'94 Bad A Z28's Avatar
Just try to find a set of 28lbers off of a '98 LS1.
Old May 25, 2003 | 04:32 PM
madwolf's Avatar
Yep, and accomplish exactly nothing. LS1 injectors will flow a little less than stockers on the LT1 pressure.
Jan 13, 2015 09:52 PM
ChrisFrez
Jan 4, 2015 08:43 AM
cmdeshon
Dec 27, 2014 10:06 AM
pete53
Dec 9, 2014 07:31 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
