Has anybody ever had needle roller cam bearings installed?
Old Aug 10, 2005 | 08:56 PM
thesoundandthefury's Avatar
If so, was it a requirement that you HAD to have your block hot tanked before they could bore out the cam tunnel? The reason this is even a concern for me is because I've spent a considerable amount of time polishing my block mirror smooth, and I don't want to have to repolish it after having been dipped in the hellish brew contained in a hot tank. The machine shop I've consulted with to work on my block has told me this is a requirement: I'm trying to determine if they're just going after the extra dollar...
Old Aug 11, 2005 | 08:25 AM
CANTONRACER's Avatar
Re: Has anybody ever had needle roller cam bearings installed?
Sorta of a mute point being they are going to hot tank it after the machine work is done...right?
Old Aug 11, 2005 | 12:17 PM
I was always under the impression that hot tanking was an option reserved for blocks that had alot of oil/grime built up or had sat outside for long periods of time and accumulated rust? My block right now is clean enough to eat off of. Is hot tanking a necessary step in the machining process or can it be skipped?
Old Aug 11, 2005 | 12:27 PM
If the block is clean and then you have machining done to it...then I would simply make sure all the oil galley plugs are out, freeze plug are out and soap and water.
When any machining is done to a iron block..the pieces of metal are not what should concern you...it is the layer of iron that is like dust that sticks everywhere that an airgun will not get off.
Queens94z28
Dec 20, 2014 09:11 PM
chuyz28
Nov 25, 2014 11:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Jul 4, 2005 05:00 PM
