Harness lead at 6 speed ?
I've put the motor back in the car and there is a foil wrapped lead above the tranny I can't seem to find a home for??
Comes off the harness just about where the tranny hits the motor on the driver side?
Any input whould be helpful!
Kirk
Kirk
Damn! You guys are good!!
It is the low oil sensor. Totally spaced that one.
Thanks so much!
Damn near ready to fire this sucker up! Sounds like you want to let it completely warm before you put load on it. So I figure I need to bleed entire brake system, fill/bleed power steering, bleed coolant before I hit the country roads and do some blasting.
Thanks AGAIN@@!!
Kirk
Thanks so much!
Thanks AGAIN@@!!
Kirk
stockssn2o
May 25, 2015 08:54 AM
Alex Barnes
Jan 24, 2015 10:21 PM
mark0006
Dec 25, 2014 09:50 PM
