SIEZED!...Help!
Old Feb 15, 2008 | 10:49 PM
Austin_78@msn.com's Avatar
SIEZED!...Help!
Here we go.......
so my car has been sitting for like a year before i bought it and i have recently figures out that it is siezed and i cant even manually turn it....SO...i am going to try to squirt some oil into the spark plug spots to see if i can lube up the cylinders a little but is there any way anyone knows how to get this thing un-stuck without tearing apart and/or removing the whole engine?
Old Feb 16, 2008 | 12:20 AM
ss.slp.ls1's Avatar
If you can't turn it by hand with the car in neutral, then maybe try and pop off the valve covers and see if you notice anything awry. If you seized a piston or bent a connecting rod, isn't a rebuild your only option?
Old Feb 16, 2008 | 12:21 AM
BigBadBlack93Z's Avatar
I'd start w/ draining the oil and seeing how big the pieces are that come out.
Old Feb 16, 2008 | 12:59 AM
i had done that already and there was no pieces...just water from my blown head gasket
Old Feb 16, 2008 | 01:00 AM
well...i guess that really would be the only one
Old Feb 16, 2008 | 01:03 AM
ss.slp.ls1's Avatar
Oh...hydrolocked? What I would do is remove the sparkplugs and rotate the engine by hand to get the water out. You could cross your fingers and hope that there is no damage...that may be a lil too optimistic, but anything is possible. Good luck.
Old Feb 16, 2008 | 06:20 AM
aboatguy's Avatar
How long did the water from the blown head gasket sit in the cylinder bores (IE did it blow a head gasket and sit a year?) If so plan on a rebuild
Old Feb 16, 2008 | 08:19 AM
indirocz28's Avatar
use a funnel with a flexible neck, and pour diesel fuel down in the cylinders and let her sit a couple days,Or, shoot some PB blaster in there- that works good too, however, if the engine hydrolocked, plan on some new connecting rods and maybe pushrods..
If its been siezed for that long- you should rebuild it anyway. Its not worth the risk of just un siezing her and then replacing your headgasket.. Good chance that when you get it un stuck you will break some piston rings..
Old Feb 16, 2008 | 03:33 PM
yeah im pretty sure it did
Old Feb 16, 2008 | 03:36 PM
yeah im thinking i might have to
Old Feb 16, 2008 | 03:38 PM
???whats this and where can i get it if i decide to do this?
Old Feb 16, 2008 | 03:41 PM
indirocz28's Avatar
PB Blaster is a rust penetrator, probably one of the best on the market. It comes in a white aresol can with a yellow lid and says " PB BLASTER" real big on it..- you can pick it up at autozone, advance auto, napa, carquest..- whatever you have around you.. - if you cant find it, just ask..
You might have to fill the cylinders full of it and let it sit for a couple days, but i bet that stuff will get it to break free...
Old Feb 16, 2008 | 05:59 PM
maverickmk's Avatar
even if you get it "unstuck" it will need to be rebuilt, most likely rust on the cylinder walls, I wouldn't mess with it, you will probably break a ring and gash the cylinder wall and if it goes deep enough the block will be useless - JMHO
Old Feb 16, 2008 | 08:52 PM
ss.slp.ls1's Avatar
+1...
http://store.summitracing.com/partde...0&autoview=sku
Old Feb 16, 2008 | 09:05 PM
yeah.....
well time for the rebuild
ill try and keep you guys posted on the progress!
thatks for the info though i really appreciate it.
