harmonic/seals
Old May 10, 2006 | 10:39 AM
radarb8's Avatar
harmonic/seals
I want to remove the hamonic balancer on my 1995 to repace the seal that is leaking and need to know if a universal remover will work or is the LT1 need a special remover?
Old May 10, 2006 | 11:54 AM
Jeff95TA's Avatar
Re: harmonic/seals
I used a universal 3-claw puller and a 1/4" drive extension bottomed inside the crank bolt hole.
Old May 10, 2006 | 01:54 PM
Mtrhds94Z's Avatar
Re: harmonic/seals
You need to remove the balancer and also the hub that it bolts to..
Old May 11, 2006 | 02:06 PM
radarb8's Avatar
Re: harmonic/seals
What is the proper way to reinstall ? Will a universal puller/reinstaller work to put the hub back on?
