Harmonic balancer still wobbling -- Crank hub?
Old Mar 19, 2012 | 12:43 AM
  #16
8cylinders>4's Avatar
Re: Harmonic balancer still wobbling -- Crank hub?
Originally Posted by greenformula94
they are cast iron on the lt1 and the lt4 is Cast iron with undercut and rolled fillets.
the pistons are Eutectic aluminum/silicon alloy, and the rods are Powdered metal, and block is cast iron.
just googled that.
The internet isn't always a good place for good info, there are a few distinctions i would like to make in interest of not spreading bad info
The cranks in Lt1's and lt4's are in fact nodular iron and not cast iron. Nodular iron is stronger. Stock nodular iron cranks are nice pieces and are considered by many to be much stronger than after market "cast iron" cranks.
Considering the OP has a 94 Engine listed in his sig and im going to say that his rods are not powdered metal. They are the pink rods which are actually forged but so many people say they are cast for some reason. However they are not quite as strong as the powdered metal rods in later LT1s
Old Apr 4, 2012 | 05:53 PM
  #17
tylerwerrin's Avatar
Today's the day... i'm removing and installing the hub. Wish me luck!
Old Apr 4, 2012 | 06:08 PM
  #18
jloshotz's Avatar
Good luck, be sure to post your results!
Old Apr 4, 2012 | 06:34 PM
  #19
greenformula94's Avatar
ya, let me hear your results
Old Apr 5, 2012 | 02:15 PM
  #20
bw_hunter's Avatar
Well, not to be picky but the stock crankshafts in both the LT1 and the LT4 are cast items. Their composition is nodular iron, which is more ductile than the standard iron materials used in crankshafts because of a high graphite content.
There are basically only two methods of making a crankshaft, casting and forging....regardless of material.
The 1994 engines had the powdered metal rods....at least the late model year engines did.....
Old Apr 6, 2012 | 05:28 AM
  #21
My late model year 94 had the PM rods.
Old Apr 6, 2012 | 09:25 PM
  #22
Hi guys,
just wanted to give an update to the wobble --
looks like replacing the hub has cut the wobble down to almost nothing. i ended up putting my original balancer on the new hub, just for giggles to see how it looked. much to my amazement, 99% of the wobble was gone.
I don't have a video of a balancer of a confirmed "perfect" car, but the hub replacement looks to have pretty much corrected the problem.
thumbs up greenformula for selling me the hub! i'll keep my eye on it in the coming days, and perhaps eventually upgrade to an ATI, to eliminate any other possible problems. They are on ebay for around 300 now i think.
thanks again for your help everyone! if anyone has a chance to post a vid of a perfect running dampener, i'd love to check it out to compare!
Old Apr 6, 2012 | 09:39 PM
  #23
Glad i could help!
Old Apr 7, 2012 | 12:13 PM
  #24
jloshotz's Avatar
Good to hear
Boss002
Jan 20, 2016 12:17 PM
88IROC_Z
Jul 22, 2015 11:38 PM
RallyRed701/2
Jul 20, 2015 11:18 AM
Catmaigne
Jul 14, 2015 05:17 PM
