harmonic balancer bolt question,..
Old Oct 21, 2003 | 09:23 PM
wjones43's Avatar
just finished some re-assembly and have lost parts and pieces-Thinking that I could just pick-up the three bolts for the front harmonic balancer from the local Home Depot- Anybody know what size bolt and thread pitch ? -On replacement,should Anti-Seize or Loc-Tite compound be applied-
TIA
Old Oct 21, 2003 | 09:26 PM
FastZinTennessee's Avatar
Sometimes when I can't get the size of a bolt or nut, the guy that works at the parts counter at the local chevy dealer has looked it up for me. I'm sure a parts guy where you live has access to the same info. That way you can go to the hardware store and pick up the bolts.
Old Oct 21, 2003 | 09:29 PM
RamAir95TA's Avatar
Re: harmonic balancer bolt question,..
TIA
It's a 7/16" 14 x .88, .70 THD, .86 OD. GM part number 9442448. Comes in a set of three.
Anti-seize would not hurt, but that bolt isn't really susceptible to seizure.
Also, buy a parts tray while you're at it.
Old Oct 21, 2003 | 09:32 PM
95 Z/28 LT1's Avatar
Super Moderator
Not to hi-jack this thread or anything, but if anyone reading this who happens to have the GM part # for the hub bolt could post it I would really appreciate it.
Old Oct 21, 2003 | 09:37 PM
RamAir95TA's Avatar
The bolt and the washer are listed as two different pieces for some reason; the washer on the stock bolt is press-fit onto the shank of the bolt.
Bolt: 9440024.
Washer: 10128306
Old Oct 21, 2003 | 09:49 PM
atljar's Avatar
Washer isnt a press fit..mine came off easily. Maybe yours was just stuck
HectorM52
Jul 30, 2017 11:46 AM
ChrisFrez
Jan 18, 2015 08:05 AM
ChrisFrez
Jan 11, 2015 03:47 PM
smokin5s
Jul 24, 2003 10:47 PM
1LEThumper
Jul 14, 2003 12:45 PM
