harland sharp rockers, any good?
Old Mar 17, 2007 | 04:30 AM
95LT1conv's Avatar
have an opportunity to pick up a set of these (1.6/,7/16). How are they compared to others like pro mags and how well would they work w/ stock cam and 918 springs?
Old Mar 17, 2007 | 08:35 AM
chrism400's Avatar
In your situation, they are going to be more than adequate. You will have to run guideplates with those. Soak them in oil overnight before you install them.
Old Mar 17, 2007 | 08:46 AM
Z-RATED94's Avatar
And make sure you run some hardened pushrods with the guideplates.
Old Mar 17, 2007 | 09:01 AM
95LT1conv's Avatar
ya, i already have GMPP guideplates and comp hi-tech pushrods. they are used (2k on them). do i still need to soak em'.
Old Mar 17, 2007 | 09:05 AM
Z-RATED94's Avatar
Probably not. Those are some nice parts you have there. Nice to see your doing it right, even if you are using the stock cam. You'll be all set, if you up-grade in the future.
Old Mar 17, 2007 | 09:26 AM
95LT1conv's Avatar
well scratch the harland's. someone got em right before me. how about crower rockers, those as good as pro mags?
Old Mar 17, 2007 | 09:27 AM
mdacton's Avatar
crowers are better.....I had harlands and had problems with them
Old Mar 17, 2007 | 09:32 AM
Z-RATED94's Avatar
Speed inc. is very fond of the Crowers. I would have purchased them, but everyone seems to think the Promags are just fine.
Old Mar 17, 2007 | 09:37 AM
95LT1conv's Avatar
thanks guys. I'll let you know what i end up with.
Old Mar 26, 2007 | 06:36 PM
95LT1conv's Avatar
well, i ended up getting a good deal on a set of Harlands. am i gonna have to mod the valve covers with these like you do w/ pro mags?
Old Mar 26, 2007 | 09:23 PM
chrism400's Avatar
A little trimming may be needed inside, and the baffle will have to be crushed narrower with a pair of pliers but that's about it.
oldschool
Feb 9, 2016 09:21 PM
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
