View Poll Results: What plug was the hardest to change?
Cylinder 1
2.78%
Cylinder 2
22
61.11%
Cylinder 3
0%
Cylinder 4
2.78%
Cylinder 5
2.78%
Cylinder 6
5.56%
Cylinder 7
0%
Cylinder 8
9
25.00%
Voters: 36. You may not vote on this poll
Hardest plug change
Old Jul 23, 2005 | 09:03 PM
  #16
My Iroc Z28's Avatar
Re: Hardest plug change
Originally Posted by RedRyder518
For all you dual cat guys, by dropping the drivers side y-pipe, you get EASY access to the #8 plug. I'm not sure if you can do that with the single cat because the dual cat y-pipe is in two sections.
i was able to take the starter off and slip my hand in there to change the plug without disconnecting the exhaust. headers make things easy it's the A.I.R pipe that make #2 a PITA
Old Jul 23, 2005 | 10:57 PM
  #17
LT1Squirrel's Avatar
f&$k 2
Old Jul 23, 2005 | 11:37 PM
  #18
danjayh's Avatar
dumb q:
Am I correct in assuming that cylinder numbering is:
...............1 2 3 4
front of car--------firewall
...............5 6 7 8
Old Jul 23, 2005 | 11:48 PM
  #19
Actually it's drivers side 1,3,5,7
passengers side 2,4,6,8
and #2 sits right below the ALT and has to be changed from the top
Old Jul 23, 2005 | 11:50 PM
  #20
Black1995Z's Avatar
This is an easy question, its the bitch on the front of the block on the passenger side.
I used a 1" extenstion and a short rachet with a pivot, helped mucho.
All the driver's side from the bottom and all the passenger side from the top.. its easiest for me!
Old Jul 24, 2005 | 12:36 AM
  #21
SantaCruz163's Avatar
Damn, number 2?!?!?! That took me no more than 5 minutes with the alternator still on the car. Reasone number 8 was a PITA was because I didn't remove the starter and my arm wasn't long enough from the top. I had the brother under the car guiding me and got it. I think the next time I ever do plugs on an LT1 FBody it will take no more than 2 hours. I didn't have to use any u-joint sockets. Just the spark plug socket, small extention and ratchet.
BTW. my hands are not that small. I just know how to more/work them
Dark Zeiro
Mar 11, 2015 07:15 AM
captcorvette
Mar 7, 2015 12:37 PM
jasonduaine
Mar 7, 2015 09:44 AM
grgguy
17
Feb 23, 2015 07:57 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
