Hard to start when cold
Old Feb 27, 2006 | 04:37 PM
tdegraw's Avatar
I have a 94 lt1 that is hard to start when cold I have to open the trottle about half way then it will start. After it starts you can cut it off and it will restart with no problem. If it sets for about 15 min it has the same problem.
Old Feb 28, 2006 | 05:29 AM
Guest47904's Avatar
Guest
Re: Hard to start when cold
Do a search. This topic has been done to death. Oh yeah, check your oil for fuel smell.
Old Feb 28, 2006 | 07:20 AM
Could be several things....
-faulty coolant temp sensor
-leaking injectors flooding the cylinders
-fuel pressure bleeding off on shutdown
Might want to start by testing the fuel pressure, and watching how fast it leaks down on shutdown.
Old Feb 28, 2006 | 10:21 AM
CALL911's Avatar
Depending on "how cold" it is, and if you have bypassed the T-body, that might be something to look at. It could be a ton of things though, and as stated before, this is not the first time this thread has been posted.
Old Feb 28, 2006 | 01:54 PM
tdegraw's Avatar
Thanks will do some research
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jan 23, 2015 01:13 PM
Britbilly
Jan 7, 2015 08:49 PM
jayblev95
Dec 1, 2014 06:55 AM
