Hard to start and hesitation
Okay here goes I have a 1993 trans am. Its a lt1 a4 My first problem. Car has a hard time starting after it sits for more than 30 min. I looked trought the search forums and found some things to test for I will do them tomarrow and get back to you with my results. Has anyone solved this problem if so tell me what you did to solve it. Second problem it hesitated a little of the line and in stop and go traffic only in first and second at low rpm's(under 2000). What might the cause be? This car is 100% stock and has only 97000 on it. Any and all help is very much appreciated
thanks Rusty
thanks Rusty
Last edited by tealman92; Aug 23, 2004 at 04:29 AM. Reason: forgot the mileage of the car
Re: Hard to start and hesitation
>I hope this link helps ... http://www.mainstreamtopics.com/foru...p?showtopic=78
Originally Posted by tealman92
Ok here are my results
10 psi as it primes
0 after its done priming
So I guess my next step is find out where in loseing pressure.
Fuel pump or injectors right?
10 psi as it primes
If your leaking through the fuel pressure regulator pull the vaccum line off the fuel pressure regulator to see if fuel is coming out. but i you got 10 PSI at prime thats waaay below spec. I'd put my money on your fuel pump...
Cool thanks man Im pretty much an expert in changing the pump in these cars since I have owned 4 of them so far. I can get it done in less than 3 hours so I know what I'm doing on saturday morning
armedtrigger
Feb 24, 2015 08:30 PM
Alex Barnes
Jan 24, 2015 10:21 PM
