Hard to start and hesitation
Old Aug 23, 2004 | 04:28 AM
tealman92's Avatar
Okay here goes I have a 1993 trans am. Its a lt1 a4 My first problem. Car has a hard time starting after it sits for more than 30 min. I looked trought the search forums and found some things to test for I will do them tomarrow and get back to you with my results. Has anyone solved this problem if so tell me what you did to solve it. Second problem it hesitated a little of the line and in stop and go traffic only in first and second at low rpm's(under 2000). What might the cause be? This car is 100% stock and has only 97000 on it. Any and all help is very much appreciated
thanks Rusty
Last edited by tealman92; Aug 23, 2004 at 04:29 AM. Reason: forgot the mileage of the car
Old Aug 23, 2004 | 04:34 AM
bowtiepwr's Avatar
Re: Hard to start and hesitation
>I hope this link helps ... http://www.mainstreamtopics.com/foru...p?showtopic=78
Old Aug 23, 2004 | 08:11 PM
chrism400's Avatar
Make sure you check your fuel pressure!
Old Aug 24, 2004 | 02:05 PM
tealman92's Avatar
ok Ill check the fuel pressure and get back to the board
Old Aug 25, 2004 | 02:14 AM
tealman92's Avatar
Ok here are my results
10 psi as it primes
0 after its done priming
So I guess my next step is find out where in loseing pressure.
Fuel pump or injectors right?
Old Aug 25, 2004 | 03:35 AM
TobyZ28's Avatar
10 psi as it primes
Sounds pretty brutal, it should be above 42 at priming (key on, engine off). It should stay there too. Engine idling it should be around 36 psi.
If your leaking through the fuel pressure regulator pull the vaccum line off the fuel pressure regulator to see if fuel is coming out. but i you got 10 PSI at prime thats waaay below spec. I'd put my money on your fuel pump...
Old Aug 26, 2004 | 03:26 PM
tealman92's Avatar
Cool thanks man Im pretty much an expert in changing the pump in these cars since I have owned 4 of them so far. I can get it done in less than 3 hours so I know what I'm doing on saturday morning
Old Aug 26, 2004 | 04:21 PM
CamaroSS30thAnn's Avatar
fuel pump...same thing happened to me ....good luck on teh install
armedtrigger
Feb 24, 2015 08:30 PM
Alex Barnes
Jan 24, 2015 10:21 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
Queens94z28
Dec 20, 2014 09:11 PM
IRABuss
Sep 7, 2011 09:08 PM
