hanging idle ?
Old May 27, 2007 | 12:27 PM
lt1street's Avatar
hanging idle ?
hey guys,
I have been having trouble with a hanging idle only on startup when HOT.The car when u start it will hange about 1500 for about 2 sec then drop down to 1300 hand for about 4 sec the goes back to normal. I have tryed cleaning the IAC vale and replaceing it to. I was wounding if it is something my computer reprogramer, PCMforless could fix ? if not what else could i try?
Thanxs grant
THe engine
355 11 to 1
cc305 cam,some porting on stock head
Old May 27, 2007 | 08:15 PM
Voridaeus's Avatar
Isn't that normal on startup? I thought the computer does that to build some oil pressure.
Old May 28, 2007 | 11:02 AM
The PCM sets the idle based on coolant temp. Make sure your coolant temp sensor is reading correctly. If its reporting a temp colder than actual on HOT startup, it could affect the idle speed.
Old May 29, 2007 | 08:25 PM
lt1street's Avatar
coolant temp sender is ok already check that.
93 RedBird
Nov 15, 2015 08:24 AM
Double aught
Oct 2, 2015 11:29 PM
95craz28
11
Sep 12, 2015 07:47 AM
tommalcolm
Sep 11, 2015 03:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
