Halfway through w/ cam install... how do you degree it?
Old Jan 14, 2004 | 12:43 AM
96LT1TX's Avatar
we are down to the cam now. I am stopping for the night to ship my lt4 timing chain and spark plug wires and to find a torx nut to get off the cam bracket holding it in. My question is, I have heard people talking about degreeing a cam, what does this mean? In the instructions I am using they dont really say anything on it, but when I asked to get it installed, it was gonna cost me an extra 50$ to get it degreed. I know it has to do w/ changing the timing slightly, but if the stock cam was lined up w/ the dots on the sprockets of the timing chain, how can you change the timing and why would you? If I see no use in it this car can be running thursday... or even tomorrow... but first day of class is tomorrow too
sorry for this ignorant question, it has been a long day of pulling things off the motor... thanks for any help.
Old Jan 14, 2004 | 12:52 AM
Brandon 95 Z28's Avatar
I just installed my cam today. I didnt degree it, i installed it dot to dot, with the cam gear at 6, crank at 12, and cam dowel at 3. I used plenty of camlube on it as well.
Brandon
Old Jan 14, 2004 | 12:56 AM
QCKZ28's Avatar
the only reason to degree a LT1 cam is to double check that it is ground correctly.
it has to be installed dot to dot method, to ensure proper ignition timing.
i didnt double check mine, just installed it dot to dot.
which install guide are you using?
jesse
Old Jan 14, 2004 | 01:04 AM
96LT1TX's Avatar
http://www.streetillusionsracing.com...ll/Cam/cam.htm
(we are on step 43, waiting for torx bits)
that is the cam install page I am using. Yep, the top pulley at 6pm, and the bottom one at 12. I dont see the big deal about it, so I guess I will just go ahead and start puttin it back together.
Did you have any troubles getting the stock cam out? Just turn it in a circle and wiggle it out very slowly? thanks for the advice guys... any more is welcome.
Old Jan 14, 2004 | 01:09 AM
S.J.S.'s Avatar
No need to degree.....just line up the dots.
Old Jan 14, 2004 | 01:40 AM
The hardest part for me was wiggling it out that first bit, I used three bolts in front of it, and it wasnt too bad. Its a little harder than i thought to bring it out totally straight without banging on any cam bearings, but its not too bad. I also had to remove my hood latch for good clearance. Good Luck!
Brandon
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
thenewkid
Apr 12, 2015 07:42 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
