Had to take the SS to the car doc!!
Old Dec 4, 2006 | 07:48 PM
97BlackSSCamaro#142's Avatar
my SS was acting up so i decided to take it to a great local mechanic to get it checked out,,the car hesitated at low RPMs, and had a horrible exhaust leak up front,,, well after dropping it off to him, he checked the EGR valve it was stuck open, the Crank sensor was bad, and the manifold bolts were loose,,,so he fixed the manifold and ordered the other parts,,hopefully the car should run better now.
Old Dec 4, 2006 | 07:57 PM
Hawk's Avatar
hopefully that fixes your problem.
Better hope it's not the opti!
Old Dec 4, 2006 | 10:45 PM
19z28camaro02's Avatar
the EGR valve, being stuck open can cause what he was describing, it can also cause misfires. little bit of carb cleaner clears it right up
Old Dec 5, 2006 | 11:45 AM
BUBBA's Avatar
What kind of 410s?
Old Dec 5, 2006 | 12:12 PM
Originally Posted by BUBBA
What kind of 410s?
Richmond
Old Dec 5, 2006 | 12:58 PM
BUBBA's Avatar
I understand that Richmonds are noisey---supposedly because the cogs are more angular, which in turn makes them stronger than the straighter ones. Don't quote me on this. It is just what I have heard. My recommendation would be to go with OEMs, and use solid spacers instead of crush sleeves.
I too have a Blk 97SS. I went with the OEMs. The 410s will make the 6th gear actually worth something. I believe it runs around 2 grand +- at 70 mph.
JMHO
Old Dec 5, 2006 | 03:09 PM
yeah hoping the 4.10 will be fun,,,6th gear is a waste in that car with the 3.42's,,,,
Old Dec 6, 2006 | 08:30 PM
Doug 97SS's Avatar
I have had 4.10's in my SS for about 5 or 6 years.....I wish I could have like a 4.30 gear....but the 4.10's are an AWESOME gear. You WILL love them.
Old Dec 9, 2006 | 10:03 PM
the EGR valve didnt need replaced just cleaned it,,but the crank sensor was bad, so it got replaced but it it still kicking a code on the scanner,,any reason for this? anyone
Old Dec 9, 2006 | 10:34 PM
SS RRR's Avatar
what code?
Old Dec 10, 2006 | 12:01 AM
Originally Posted by SS RRR
what code?
kept kicking the check engine light on, and saying the sensor was bad even though it was new
Old Dec 10, 2006 | 01:15 AM
SS RRR's Avatar
check the connection and condition of the harness to make sure it is not damaged. take the sensor out to ensure it hasn't made contact w/ the reluctor gear.
Old Dec 10, 2006 | 02:52 AM
Javier97Z28's Avatar
Moderator
JMHO
You have the right idea, but backwards
Richmond = straight cut gears.. stronger/noisier.
Old Dec 16, 2006 | 09:36 AM
well fellows, to the car to a local dealership because it still wasnt running right, well come to find out the distributor is bad,,,so im gonna upgrade all the ignition to MSD
Jazsun
Dec 29, 2014 12:14 PM
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
USAirman93
Nov 24, 2014 03:37 PM
