h/c setup how much fuel?
Old Nov 30, 2005 | 12:48 AM
hondah8ter's Avatar
well right now i have all the boltons and ported heads. im looking at the gm847 cam. im wondering what size injectors/fule pump and any other things i will need to support this. i ahve 4.10 gears already. anyway thanks for the help.
Old Nov 30, 2005 | 07:28 PM
hondah8ter's Avatar
Re: h/c setup how much fuel?
any help???
Old Nov 30, 2005 | 07:51 PM
FastZinTennessee's Avatar
Your stock fuel pump will be fine unless it's starting to go bad. Save that until you have to, your either going to end up with a hole cut in your floorpan to remove the pump or losing your religion trying to drop the damn tank out the bottom (don't even get me started).
I went to www.racetronix.com and got some 38 lb/hr injectors. They are overkill for my setup, but didn't cost much more (if any) than 32 lb/hr ones which I would have gone with.
Old Nov 30, 2005 | 10:27 PM
SS RRR's Avatar
30# and stock fuel pump will work fine. As said, make sure you check to see what the pressure is like.
DirtyDaveW
Dec 1, 2016 05:37 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
TT350
Mar 31, 2015 07:44 PM
Bignasty85
Mar 3, 2015 04:05 PM
