H and C Packages
Old Jun 21, 2004 | 06:30 PM
Toker420's Avatar
H and C Packages
I got my 383 short block done anyone know of any head and cam packages kickin out some neck breaking power for the 383's.
Old Jun 21, 2004 | 08:43 PM
1racerdude's Avatar
Yea, 18* Brodix converted for reverse flow cooling with a carb intake set up for EFI.The cam will go along with the intake flow. Over 700FWHP set up and tuned right.
Old Jun 21, 2004 | 10:25 PM
kmook's Avatar
Advanced Tech Moderator
First please use a signature so people know what year/car you have. Second general engine buildup should be posted in a generation spacific forum. Going off your other threads I will move this to LT1 Tech. Thanks.
Old Jun 23, 2004 | 04:15 PM
Toker420's Avatar
Its a 94 with all forged internals just need some ideas on head and cam. i wanna stick with a hydraulic cam and fuel injection.
Old Jun 23, 2004 | 04:26 PM
simple's Avatar
stroker, i would be looking into some bare AFR's (195's or bigger) to have sent off somewhere for race porting (etc.) and assembly
what do you have in mind for the car?
maybe contact Phil @ www.advancedinduction.com
Old Jun 23, 2004 | 04:29 PM
Toker420's Avatar
Llyod gave me a quote for $1600 for my heads redone and custom cam that would put down 410 to 430rwhp. So if thats my best bang for the buck im gonna go with that.
Old Jun 23, 2004 | 05:52 PM
ARTIC_Z's Avatar
700FWHP?????
Old Jun 23, 2004 | 07:14 PM
slomarao's Avatar
go to advanced induction, or LE. Those are the two bigges now. Both have been making over 400rwhp with their packages. If I was doing a HC build up that is where I would be spending my money. AFR makes some of the best heads. Send a pair of 195's to phil or lloyd.
Old Jun 23, 2004 | 07:19 PM
simple's Avatar
a stroker motor deserves some big port AFR's IMO
not off the shelf AFR's either but competently worked over AFR's
or Trick Flows
Old Jun 23, 2004 | 08:57 PM
97Z-M6's Avatar
personaly i would call loyd and ask about his le3 cam and using stock heads. you may be surprised
IndyZman
Oct 22, 2015 02:17 PM
Z Power
Sep 19, 2015 11:19 PM
cmsmith
Sep 14, 2015 09:25 PM
NewsBot
Sep 14, 2015 08:50 AM
cmsmith
Aug 9, 2015 07:30 PM
