H/C LT1 results
Old Sep 12, 2006 | 03:41 PM
  #16
ABA383's Avatar
Re: H/C LT1 results
Your numbers are fairly close to my last years track passes...Check out my sig for what a 1.55 60' would do for your 1/8th...Have since changed a few things Kooks LTs, EWP and Bogarts with 275 50 15 M/T Radials...trying for 1.4Xs...
--Alan
Old Sep 12, 2006 | 05:37 PM
  #17
94irocz's Avatar
Re: H/C LT1 results
i run 275/50/15 mt radials on my car. Just about all the bolt ons, a cam, and some gas. 1.53 60 has been the best i've cut so far. Only suspension mods are lca's and relos. car probably weighs 3560 or so with me in it maybe more. Try and find a track that will prep it and try it there.
Old Sep 12, 2006 | 07:11 PM
  #18
n20fed's Avatar
Re: H/C LT1 results
Originally Posted by MeanGreen97Z
Yup get that bad boy to hook up and you should see some 1.5x 60 foots... then your lower 7s will come. Drop the tires to 12psi or so psi and heat em up like crazy (John Force them is what I do) and you should get there.
I thought that these tires didn't require much of a burnout? Also, won't I start to cup the tires under 12psi on a 10" rim?
Old Sep 12, 2006 | 07:13 PM
  #19
n20fed's Avatar
Re: H/C LT1 results
--Alan
What hp on tq numbers are putting dyno and on what kind of dyno? Also, what rear gears are you running?
Old Sep 12, 2006 | 07:58 PM
  #20
stew's94z's Avatar
Re: H/C LT1 results
Believe it or not, I ran the times in my sig with 20 psi and a 5 second burnout in 2nd gear @ 4000. When I nail it off the line come 11-4-06, I expect a 1.50 60ft.
If your car is working, the MT DR's will hook.
Dean
Old Sep 13, 2006 | 11:16 AM
  #21
ABA383's Avatar
Re: H/C LT1 results
When I ran the the 11.50s I was 381rwhp/370 rwtq on the Dynojet...Changing to Kooks stepped LTs and an EWP and the numbers are very similar only now on a Mustang Dyno which is what I will continue to use..I run 3.73s in my 12 bolt and a 3600 Vig...
--Alan
Old Sep 13, 2006 | 12:08 PM
  #22
n20fed's Avatar
Re: H/C LT1 results
--Alan
what is your race weight, and what tranny? If a t400 do you have a transbrake?
Old Sep 13, 2006 | 01:25 PM
  #23
ABA383's Avatar
Re: H/C LT1 results
3650 race weight, built 4L60E and I launch off idle, no transbrake...It went a 10.98 at 120 on the Mustang dyno 1/4 mile blast with a 1.35 60' with the addition of an EWP and stepped Kooks...It should go 11.20s for real with the new mods, provided I can get the 60' into the 1.40s range...
--Alan
Old Sep 13, 2006 | 02:12 PM
  #24
n20fed's Avatar
Re: H/C LT1 results
Man I wish I could hook. I weigh about 150-175 less than you and were making about the same power (387 on a mustang). Good luck with your goal to 10's!!
alex5366
Feb 17, 2015 08:12 PM
alphaauto
Jan 22, 2015 08:02 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
Redbird
Aug 12, 2002 08:51 AM
