guys who had problems with the icm overheating-come inside
Old Jun 13, 2003 | 08:28 PM
fastwhitez's Avatar
anybody who had problems with the icm getting heat soaked and shutting down were there any other symptoms. because in my car the rpm gauge and the speedo go nuts every time it dies. now i crank it and the rpms go up to 6000 and its not turning over that fast and wont start any ideas
Old Jun 14, 2003 | 05:38 PM
fastwhitez's Avatar
any body??????
Old Jun 14, 2003 | 06:27 PM
JasonL's Avatar
Did you use dielectric grease between the ICM and the heat sink? If you don't, the module will overheat and die.
This is per the instructions included with a new GM unit.
Old Jun 14, 2003 | 06:39 PM
fastwhitez's Avatar
yes i used that but something is still wrong. i cant figure out why my rpms go up that high when it cranks over. would that be opti or icm?
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Alex Barnes
Jan 24, 2015 10:21 PM
USAirman93
Nov 24, 2014 03:37 PM
squarehead
Nov 21, 2014 08:02 PM
Red97LT1
Aug 7, 2002 05:45 PM
