Guys w/BMR tubular SFC'S INSIDE
Old Mar 6, 2003 | 01:17 AM
94 TA TT2S's Avatar
Question Guys w/BMR tubular SFC'S INSIDE
Just needing to know The back bolts to the control arm mount and the front is welded ...Did anyone weld the back as well seems like it might help out......My buddy has the boxed ones and his bolt on bothe sides in the rear I believe that with just having that one side , it may be nessesary to weld it in the back as well...What do you guys think or what have you all done...Thanks....
Old Mar 6, 2003 | 09:46 AM
Smokn '94 Z's Avatar
Lightbulb
Weld...
Old Mar 6, 2003 | 10:06 AM
Euclid's Avatar
so, SFC's should definately be welded?
Old Mar 6, 2003 | 10:21 AM
turbo_Z's Avatar
the shop that put mine on didnt weld the rear section since its bolted on... i this bad?
Old Mar 6, 2003 | 10:47 AM
95LT1Z28's Avatar
Thumbs up
I had a 2in. weld on the back of my BMR tubular sfc. To me the bolt is only to help aid in the installation of the sfc by helping to line it up in the front and hold the back up while the welder does his job. No need to go crazy and weld the whole thing to the back, just a 2in. weld down the back of it works fine. Make sure front is welded up good though! Hope this helps you!
Jeff
LimitedEd1LE's Avatar
Definitly get them welded. I had them weld the back part and also put a bolt through it.
Old Mar 6, 2003 | 11:22 AM
93ZM6Tally's Avatar
I have the sqare version from BMR which also have a rear bolt. However the installation instructions call for welding both the front and rear. Mine is therefore bolted to the LCA in back and welded on both front and rear. The square version have surfaces specifically designed to weld to the car on both the front and rear portions of the connectors. So get the rear welded as well.
Old Mar 6, 2003 | 11:43 AM
Euclid's Avatar
Sorry for my ignorance, but exactly what are they welded to? The chassis?
Old Mar 7, 2003 | 02:09 PM
93ZM6Tally's Avatar
Yes they are welded to the frame, (MonoBody Chassis).
Magenta_Hearts
Mar 25, 2015 10:24 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
87Aerocoupe
Jan 10, 2015 07:27 PM
Red97LT1
Aug 7, 2002 05:45 PM
