guys need help fast opti seal
Old May 21, 2007 | 07:12 PM
Daniel6718's Avatar
had an oil leak so i got the waterpump off and its the seal for it, decited to pull the opti and make sure that seal was good too...found out when i pulled the opti that the 2 little metal o rings on the shaft going into the cam are broken into pieces so i completely removed them, now they look as if they are all one part, so can i replace them? i assume they help keep down vibration on the opti? can i replace them with a think o ring???
what do yall reccomend for a fix?
this is a 95 with the shaft that goes into the cam
http://shbox.com/1/opti_back.jpg
2 rings on the shaft, you can see them both in this pic
shbox? injuneer? chime in?
Old May 21, 2007 | 07:16 PM
mdacton's Avatar
they are just rubber o-rings
pretty sure they aren't metal
Old May 21, 2007 | 09:12 PM
96flame's Avatar
Get the Felpro timing cover gasket set. It gives you the w/p ds seal, opti seal, crank seal, opti o-rings and timing cover gasket. They are just o-rings but the original ones got baked and crumbled to pieces.
Daniel6718's Avatar
mine were metal??? good to hear ill replace with rubber o ring...and the opti seal i have sitting around...a bunch of them
Old May 22, 2007 | 10:21 AM
Z28SORR's Avatar
Take one of your broken "metal" pieces and hold it with a plyers over a match flame. Then come back and report the results.
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
maybe2fast
Feb 5, 2015 05:14 AM
The Seer
Nov 20, 2014 06:32 AM
Red97LT1
Aug 7, 2002 05:45 PM
